Worn Rear Tires
Thanks everyone,
Those are good suggestions. I never knew about those rear suspension i.e. toe/alignment, LCA and etc. I will take these in consideration when take to the shop. @911mhawk, when you meant by negative camber. Meaning the wheel/tire should be a bit verticle? Here's what it looks like with the GT2 wheels setup.
Thanks everyone,
Thanks everyone,
"0" Camber would have the tires straight up and down, vertical. Negative camber means leaning in at the top. Negative camber causes more of the outside tire tread (with the most weight on it) to roll onto the pavement. Positive would allow the tire to roll onto the sidewall.
