996 Turbo x50 GT2 Gear Upgrade
Last year I pulled my diff and did uprights and it's a great improvement too.
The cooler is more important than the steel sycnchros. With the LSD the added cooling is desired. An LSD will add upwards of 20F to the temps. Since a Wavetrac is a TBD and gear driven it doesn't matter. But a proper Salisbury design with clutches needs cooling.
Easy to spend $10k+ with all new parts if you let it go too long.
Can we use this thread to put to bed the claim that some x50 transmissions got steel synchros? I've seem and heard this from multiple first hand accounts but seems like there is still some grey-area around the official answer.
Gt2 trans gets steel synchros in 3-5 which is the range of more highly used track gears! Gotta question why anyone would question if those are lower gears!
I stepped out of that debate years ago. It just doesn’t matter. When it comes time to rebuild if you track your car use steel. If not use brass. Steel shifts poorly when cold. I wouldn’t use them in my own street car.
Hi All just a quick question , I just got my 996 turbo transaxle back from being rebuilt , has 997 GT2 RS gears and shaft now and wavetrac and GT2 slave added.
I have the slave line, what other parts do I need to complete the reassembly of this , its a 2002 911Turbo. also what is the best fluid to use in this? some track days and a little autocross.
is there any rerouting of the power steering fluid from the old master cylinder that needs to be done? I read up on this a few years ago , when I want ed to do it, but I have forgotten everything..
Hi, I did a short write up on this when I did mine. Check it out...
https://rennlist.com/forums/996-turb...m-install.html
I should be getting mine back today.
Very excited.
Very excited.
