Metal clanking under braking and acceleration
A couple weeks ago I noticed a metal clanking when going slowly under braking and acceleration.
My first thought was maybe time to replace some monoball stuff that is less durable for a car that still sees a lot of street use. Potholes and pavement in Seattle is better suited to some rubber for most cars.
Then I hit the brakes pulling into a parking lot and heard the sound, only this time it was a lot worse:
I've had a 10mm fall out under braking in a different car but this thing was riding with me for about 500 miles.
Finder's keepers.
Funny. I was doing a 5bar fpr install last night and dropped my 10mm wrench around the fpr area. Could not find it and just left it behind. Hopefully it will fall out soon so I can get my 10mm wrench back
Tried to throw a wrench in your plans... busted. Was this the cause of the rattling that you blamed on your monoball mounts last time we were at Pacific?
Sorry I missed your call yesterday, busy day. I'm working from home today and tomorrow if you want to catch up!
'd look for yours, the belt and pulleys will take out other items if that 10 goes to the wrong place.
Tomorrow I'll be at PR all afternoon if you're "working from home". Hahahaha
Damn!
3/4 inch wrench and a 19mm wrench are very very close in size. Nearly identical, only .05mm difference.
Do you know of any 19mm head nuts or bolts on the turbo, other than lug bolts? don't think anyone's using a combination wrench to tighten wheels...
That is a good point. I think there are some 19mm bolts/nuts securing elements of the suspension and cross bracing but it has been a while since I have wrenched any of those parts.
It's not my wrench and my buddies shop where I do some work doesn't have any Craftsman in it.
Sometime in the next week I'll put it on a lift to change fluids and see if anything sheds light on where it was hiding.
