Transmission rattle...
No. OEM Lightweight flywheel and a lightweight OEM 996Cup pulley. Zero issues. I have my own opinion on the fancy aftermarket dampeners but I'll keep those to myself.
Interesting. My car does it too, but only when it is very hot outside. Noise goes away immediately when the clutch is depressed. I'm having a hard time trying to understand why coils/plugs would make the noise go away. I was always thinking it was either a clutch component as others have already mentioned, or something in the transmission. Did you by chance also have the transmission fluid replaced?
Dan
Dan
The transmission fluid was replaced a couple of times and had no effect on the noise. The fluid was changed at the dealer and the factory fluid used.
In fact the transmission replaced under CPO warranty when it developed a leak. The new transmission was a dream compared to the original one, a much much better shifter.
But the rattle was present with the new transmission. I don't recall now if the orignal one manifested the noise.
hello,
maby its the power steering reservoir check valves.
i'v read that if the clutch pedal is depressed and the sound goes away, its the power steering reservoir check valves..
