Clutch Face to Engine Block Dimension
05-12-2017, 06:23 PM
I have finished making the flywheel and adapter to mate the Porsche gearbox and clutch to the Audi V10 engine. Here are some pictures.
Thanks for you help.
Ray.
05-12-2017, 06:32 PM
Technical GuruRennlist Member
Are you going to use the regular starter ring too? That will normally lift the pressure plate a few mm away from the flywheel.
05-12-2017, 06:48 PM
I am using the Audi ring gear and starter motor. Here is a picture without the adapter installed.
Ray.
05-12-2017, 09:59 PM
Looks great. Please continue to share pictures as your project comes along.
07-18-2017, 11:06 PM
I now have the gearbox/transmission on the engine. The gearbox is mounted upside down. Here are some pictures.
Ray.
