Timing Chain Guide Bolt
Part nr 96410517102
This bolt got a really small oil leak, I guess pulling it out to change the sealing ring is a bad idea since this is the bolt for one of the guide rails..
Bolt leaking is for lower right guide rail.
So figure I just tighten it right, but can't find the tourque
Only found this one for 993 so far (look similar) http://www.porscherepair.us/porsche-...ling-face.html
Bolt 27 says 31 Nm
Can anyone confirm the tourque or confirm (or not) if it can be removed to change the sealing ring?
Bolt 27 says 31 Nm
