996 GT2/GT3 Forum 1999-2005
GT3 broke down - 1st tow report
Old 11-07-2003, 06:41 AM
Fongster
Fongster's Avatar
Originally posted by Weng
Car is running well again. However, I discovered a new problem when I picked it up from the shop. The brakes were beginning to judder a bit at the last track outing and I got the shop to check them out. Guess what? Numerous cracks (>5mm ) on the steel rotors - particularly the fronts. A bit of warpage on all 4 rotors. All this after only 3,000 miles - albeit with a bit of spirited track use in between. I'm a bit annoyed as I was chewing through the mk1 rotors quite quickly too. Seems that the high heat conditions over here, racing pads, and a track which is tough on the brakes will combine to boost my consumables expenditure. Have to wait a while for the new rotors to be shipped here as the dealer didn't think they would need to stock them so quickly.
Weng
If you want to, find a US dealer and drop ship it to my place in SF, I'll bring some back for you.....
Old 11-07-2003, 08:13 AM
Weng
Weng's Avatar
Fongster, thanks for the offer but I think that the dealer should be able to air freight a set out here within the next couple of weeks.
Old 11-09-2003, 04:21 AM
ruffy
ruffy's Avatar
Fongster,
you got a PM
I may need your help
Old 11-18-2003, 07:18 PM
Madcaplaughs
Madcaplaughs's Avatar
Originally posted by sjsharks
Rattles.
PCCB Brakes.
2 out of 3 cars at one location returned.
Defective fuel pump.
Seems like a fairly high incidence of problems.
Would the turbo be the better choice if dependability is a high priority?
No such reliability problems with the GT3 here in the UK.
Quick Reply: GT3 broke down - 1st tow report
