GT3 996.2 Replacement headers worth it ?
I have stock engine 996.2 GT3 with x pipe Cat bypass and factory mufflers and wonder whether it is worth changing headers to aftermarket mandrel bent to get a weight reduction and power increase but the improvement over stock seems marginal for most brands.
Another option is to use the headers and cats from a 997 gt3 then run the mufflers or straight pipes as you like. That is what I did. No mufflers, but loud as hell. I must be getting old because its almost too loud for me.
No, only if you use the 997/991 center exit muffler. Of course, you can have anything custom-built after the 997 headers and cats to keep the original bumper and side exits. I'm a huge believer in 997 headers + cats...those + heads are how hp went from 381 to 415 on 997.1. Frankly, the 996 exhaust setup sucks.
I have a full M&M cup exhaust on mine and the headers are a beautiful design that absolutely trumps the OEM gear. Very difficult to accurately quantify a difference however.
Competition headers should add some HSP, and Ive heard from Fabspeed tech it is the one exhaust product that will add the most hsp. Not knowing the 996 GT3 cars (I did test drive an '04 before I bought my 7.1), I would do some research since I assume your GT headers are pretty good even as a stock item, although seems all quality aftermarket products are less weight and some increase in hsp.
