GT 2 2004
GT 2 2004
when I turned on the GT2 2004, All warning lights on the instrument are on, I could not start the car..When I took out the key and restarted but the lights are still on.. Please help, thanks Hendrik
Hi Hendrik,
Does the engine crank over and not ignite, or does it not crank over?
Did the engine start the second time you tried?
Check You Tube and search for 996 dead battery hood unlock. You have to connect a battery charger or jumper cables from another car to the fuse box. There is a designated position to use so that power can unlock the hood. very easy however just remember to connect correctly
well that's an easy fix!
here you go:
here you go:
