BBi Autosport Black Friday Sale 996 GT2 GT3 Exhaust, Roll Bar, Suspension, IPD, Cobb
Basic Sponsor
Attachment 1358175
This year has been great to us and Thanksgiving is great time to show appreciation for the love and support from our customers and friends. We are running a special Black Friday Sale promotion for on our entire BBi Autosport catalog, along with selected products from our partners. Here are the BBi Porsche 996 GT2 & GT3 upgrades that will be on sale:
BBi Autosport StreetCup Porsche 996 GT2 GT3 Roll Bar
![](https://c2.staticflickr.com/8/7653/16382546854_70f34274b2_h.jpg)
![](https://c2.staticflickr.com/8/7623/17004957125_bffd4c0f82_h.jpg)
Features
IPD Porsche 996 GT2 Plenum
Competition Version with 74mm Throttle Special Package Deal Also Available
![](https://c2.staticflickr.com/6/5718/23226098752_8727281015_h.jpg)
As part of our Porsche 996 Turbo/GT2 BBi Power Package, the highly acclaimed IPD Intake Plenum was designed, developed and tested at our facility to work in perfect harmony with our highly acclaimed Barcode exhaust system and the Cobb Access Port ECU Tune. Being our dedicated technical partner, IPD has been developing patented intake plenum upgrades for Porsche vehicles since 2004 - now covering more than 30 applications distributed worldwide - and continues to share the same facility and technical resources
Features:
Cobb Tuning Porsche 996 Turbo / GT2 Accessport V3
![](http://media.cobbtuning.com/catalog/products/accessport_v3_extra_01.jpg)
No performance upgrade is complete without a tune to reliably extract as much power as possible while maintaining excellent drivability and consistent results. The Accessport for the Porsche 996 Turbo / Gt2 is the ONLY handheld flash option. Being the world's best-selling and most flexible ECU upgrade solution, the Accessport V3 comes with Stage 1 and Stage 2 Off The Shelf maps as well as complete custom tuning capabilities for any modification level.
Features
BBi Autosport Porsche 996 Turbo / GT2 Barcode Exhaust System
![](https://c1.staticflickr.com/1/420/18634450946_dee8eb165f_h.jpg)
![](https://c1.staticflickr.com/1/340/18676990392_559a63e03d_h.jpg)
Features:
BBi Autosport Porsche 996 GT2/ GT3 StreetCup Suspension Components
BBi Street Cup Suspension Components Typically Share The Following Features:
BBi Autosport Front & Rear Lower Billet Control Arm Kit
![](https://farm9.staticflickr.com/8654/16663204341_71cf0fbbfd_h.jpg)
![](https://farm9.staticflickr.com/8602/16457964687_2d960ac66c_h.jpg)
(shown with optional camber and litronic shims)
BBi Autosport Front Bump Steer Kit
![](https://farm9.staticflickr.com/8680/16532471130_fe619ddc60_h.jpg)
BBi Autosport Rear Adjustable Toe
![](https://farm9.staticflickr.com/8675/16702789656_64a3cb486c_h.jpg)
BBi Autosport Front & Rear Thrust Arm
![](https://farm9.staticflickr.com/8594/16512680580_5d823c886d_h.jpg)
BBi Autosport Front & Rear Adjustable Thrust Arm Bushing Kit
![](https://farm9.staticflickr.com/8584/16037662063_46dcf21b3a_h.jpg)
BBi Autosport Rear Upper Control Arm Kit
![](https://farm9.staticflickr.com/8571/16104616624_13fa5fd5a8_h.jpg)
Please email us at Jerry@BBiAutosport.com or Sales@BBiAutosport.com to place an order or for all questions and inquiries!!!
Features
- 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
- Made from 4130 chrome moly steel tubing (1.5" x .120" main hoop & 1.5" x 0.95" rear hoops) for excellent strength to weight ratio
- TIG welded and utilizes "X" braces on both front and rear sections for superior strength and rigidity
- Mounts to front seatbelt mounts and rear strut towers
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise and seamless fit
- Designed to work with stock or any aftermarket seats on the market
- Can be used with stock seatbelts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other optional colors available
- Designed to fit all models of the 996 and 997 chassis including the Carrera, Turbo, GT2, and GT3
- Compatible with factory Bose subwoofer
- Bolt-in installation requires no drilling and minimal carpet trimming
- Made in USA
Features:
- Increases horsepower, torque, and boost responsibly optimizing air flow efficiency
- Designed with 3D Modeling & Computational Fluid Dynamics software
- Utilizes diversion splitter and dimpled interior surface eliminate turbulence and increase air flow
- High quality cast aluminum construction
- Direct fit OEM replacement
- Made in USA
Features
- Simple Installation: Everything is included for the simple installation you can do in your driveway! Intuitive on-screen instructions identify your exact vehicle, saves stock vehicle data, and displays available OTS maps.
- Change Maps: Store up to 100 maps from our OTS map database or from your favorite COBB tuner and quickly switch between them for any need.
- Vehicle Upgrade Support: As you continue to modify your car, Accessport maps can be used to optimize performance upgrades. Changing the map can be done in less than 1 minute in your driveway.
- In Car Mount: The Accessport can be mounted in vehicle to allow you to monitor the performance data.
- Data Logging: Record multiple data channels simultaneously for in-depth evaluation of engine performance. Stores up to 1 hour of continuous data.
- Gauges: Use your Accessport as a gauge to monitor boost or any other live information, directly from the ECU.
- Trouble Codes: Read engine trouble codes to diagnose issues. Clear them when resolved. Prevent expensive trips to the dealership.
- Full Uninstall: Using the Uninstall option will completely remove our programming from the car’s ECU. It is then able to be re-installed after a dealer visit or on another vehicle.
Features:
- Produces more aggressive exhaust sound
- Reduces restriction to increase horsepower, torque, and improve throttle response
- Crossover X-Pipe
- 304 stainless steel aerospace tubing
- 3" diameter piping throughout system
- Meticulously TIG welded
- Brushed stainless finish
- Significant weight savings
- HJS OBD2 compliant 200 cell catalytic converters
- No CEL (Check Engine Light)
- Direct bolt on replacement
- Stylish design with laser etched BBi logo
- Optional high temperature black ceramic coatings available
- Handcrafted in the USA
- Hard tested on the street and track
- Provides additional adjustment range
- Helps maintain proper suspension geometry
- Utilizes turnbuckle design to be lengthen or shorten links to desired specifications
- Eliminates factory rubber bushings for improved suspension feedback
- Direct bolt-On replacement and requires no modification to the vehicle
- Made of precision CNC machined 6061-T6 aerospace grade billet aluminum
- Precision Teflon lined spherical rod ends for smooth operation and long life
- Discrete black anodized finish for increased corrosion resistance
- Made in USA
- Improved two piece 996 GT3 lower control arm design
- Stronger than cast motorsport Cup arms
- Allows proper camber adjustment 996 & 997 Models
- Uses GT3 shims to adjust camber & lower control arm length (sold separately)
- High-strength steel alloy spherical bearings, completely serviceable unlike the motorsports arms
- Sealed monoball inner bearing
- Allows easy access to inner arm hardware
- Includes adjustable thrust arm bushings to adjust adjust caster and wheelbase
- A must have for all track and race enthusiast
- Each kit includes pair of 2 arms
- Fits both front and rear axles
- Part Number BBILOWRCNTRL9697
- Helps eliminate bump steer by maintaining proper front end suspension Geometry
- Utilizes misalignment rod ends of the arm to provide maximum articulation
- Highly recommended for vehicles that have been lowered
- Each kit includes pair of 2 Links
- Part Number BBIBUMP9697FRONT
- Provides additional rear toe adjustment
- OEM link is non adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
- Helps maintain proper rear end suspension geometry
- Part Number BBITOE9697REAR
- Connects the Lower Control Arm to the subframe
- Provides precision caster adjustability
- Spacers included for setting stock or anti-squat and anti-dive configurations
- Each Kit Includes Pair of 2 Links
- Part Number BBITHRUST9697
- Provides two eccentric mounting points
- Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
- A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
- Compatible with all stock Porsche 996 and 997 lower control arms (including Porsche Motorsport Cup arms)
- Complete set of 4 (2 front & 2 rear)
- Part Number BBITHRUSTBUSH9697
- Link the rear wheel carrier to the sub-frame.
- Allow adjustment of track width and kinematic toe.
- Complete set of 4
- Part Number BBIDOGBONE9697
![](https://rennlist.com/forums/signaturepics/sigpic165623_1.gif)
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
