Water Pump
Water Pump
Its time to change my water pump, leaking. Which pump do you guys reccommend? There are composite pumps and metal blade pumps, both which appear to be OEM. Anything else I should do while I'm in there?
The factory installed Boxster water pump lasted 172K miles and the factory installed Turbo water pump lasted around 120K miles. I'm happy with the longevity and neither suffered any mechanical failure. The Boxster pump got a bit grumbly and the Turbo water pump developed a leak.
Also, I was always taught when changing the water pump replace the T-stat too. In fact I was advised to "test" the old T-stat and the new one in a pot of water on the stove to verify the new T-stat opened at the right temperature and fully opened. The old one was there to provide a reference as to how the new T-stat was working. This assumes the old T-stat was working ok to begin with, of course, which is most of the time.
(I can assure you the techs don't bother with this, but simply rely upon new T-stat being ok right out of the box.)
Unless the coolant is "fresh" this could be a good time to replace the old coolant with a proper mix of Porsche anti-freeze and distilled water. For this you probably want to consider getting some kind of a vacuum lift system that draws a vacuum on the cooling system then with the flip of a valve allows this vacuum draw in a fresh mix of coolant from some reservoir filled of course with fresh coolant.
This helps ensure the cooling system is filled with no air pockets and without the horrible procedure of getting the engine hot then topping up and repeat over and over again as one works the air pockets out of the system.
Thanks Macster. Great info. I'm def goint to change the t stat, and probably do plugs and serp belt too. I'm ordering today so if someone has a brand name I should go for, I'll do it, otherwise I'll take the one they say is OEM. Many Thanks!
I'd use OEM. There was a thread on here by user Berger who had really bad luck x2 with aftermarket pumps.
FWIW - the pump itself doesn't have any pipes attached to it, the fitting that it sits inside has the fittings.
Suncoast has recently reduced the price on the Porsche part, which has been more reliable than the 3rd party options.
http://www.suncoastparts.com/product...610634071.html
