Longevity of axles on track car?
Don't know if these fit GT3, but price is not a lot more than stock:
http://www.driveshaftshop.com/import...1-2004-996-gt2
CVJ axles does a rebuild and race prep option for the OEM axles that pretty reasonable considering the cost of a new OEM unit.
One local friend and rennlister is getting ready to ship his off to them soon. Since my car is apart for freshening this winter I'm strongly considering doing this myself as well.
In my opinion, the axles are not that much of a concern (from a safety standpoint anyway). If you break an axle it won't cause you to loose control of the car. I had over 100 track hours on my axles without any issues and that is on a car cranking out 600hp. I would be much more concerned with hubs or lower control arms. I broke a rear hub recently in a high G right hand turn which then destroyed the axle, brake rotors, and upright in the process. I changed everything which includes both uprights, bearings, axles, thrust arms, toe arms, LCAs, and hubs. I went with 997 hubs that are redesigned and thicker. I also changed out the LCAs to the much beefier PMNA RSR units as a local 6GT3 recently lost a rear OEM LCA (outer ball joint snapped) and it did some major carnage to the car. That was a wake up call. I changed the toe arms to the Cup PMNA arms with the pinch bolts. People don't realize how much stress is put on all the suspension components and they will fail eventually. Not a question of if, but rather of when...
[url=https://flic.kr/p/oBB2Px]
Axles don't always break where you expect them to. This happened to me last year and caused the ABS to freak out due to a wobbly wheel, which caused me to flat spot the tires and go off.
Part of why the Cups break them has nothing to do with shock loads. It has to do with ride height and axle angle. Rarely do street GT3s used on track see the same aggressive setup used on them.
Can you elaborate further on that? Are the CV at an angle that is causing them to bind? What angle are they at?
