Check your wheel hubs if you track your cars boys and girls.....
#31
#32
It's possible. I think we looked at 991GT3/4 hubs and those were different if I recall correctly. Either way, the 991 hubs are still die cast pieces so nothing new there from a strength standpoint and there is no way to increase the area of the failure point due to the constraints of the bearing race and OD of the drive shaft splines. A forged material is really the only way to go. The 300M hubs will also be cryoed and heart treated. I wish there was a cheap solution. We looked at using the Grand AM Cup hubs but upon examination did not find them of any benefit from a strength standpoint.
#34
Thanks,
I wonder what the root cause was... It would be interesting to have a ME look at these parts.
Have you looked at the RSR / cup car hubs?
Ray
Ray
#36
Yes, we looked at Cup hubs, specifically the Grand Am hubs which are not center lock but set up for a 5 lug set up. Surprisingly these hubs are also relatively inexpensive at several hundred per hub but they are still a simple die cast hub. I believe the reason you do not typically see failures of the Cup parts is most likely the fact that parts are swapped out on a much more frequent maintenance schedule that on street cars, many parts being changed out on an annual basis or an hour limited schedule.
#37
Thanks,
Gotta ask, With the money and time you have invested in this beast and the performance levels you are looking at, what about just timing out some of these parts? Carriers & wheel bearing say 20 hours / 1000 miles?
Ray
Ray
#38
For the most part I do that already Ray. I also stay away from any of the aftermarket stuff instead sticking with genuine Porsche Motorsport parts like the RSR control arms, toe arms, etc.. The hubs just seem to be a particular weakness especially when run on a platform with a stiff suspension (1500 lb springs), sticky tires, and a high hp/tq engine. I believe I've just pushed that particular part past the design limit as it is always the left rear that fails, which just happens to be the most highly loaded corner on my car at my track (predominantly right turns).
#39
This is interesting to me because this is the point that I was with my last track car - A STi. Hubs & bearing were timed out every year - as was a number of other things. I STILL broke a lot, to the point where I just got a GT3.
My car has centerlocks (it came with them). The are just the standard part drilled out to receive the drive pins
The other interesting ting is that I don't see many places suspension wise, where the Porsche design envelope is exceeded...
The hubs you are getting built are quite nice.
Ray
Ray
#40
Ray
Ray
[url=https://flic.kr/p/G2apij]
[url=https://flic.kr/p/GkrjEc]
[url=https://flic.kr/p/FtJ8e4]
[url=https://flic.kr/p/Giabor]
#41
Wow, that is some carnage...
I totally agree with you on the aftermarket, not always worth the money. I did just get a set of 4 of the 'tarret' cup arms, not cheap, but worth it. I considered the MS stuff, but went with this because it was a bit easier, and these are very well made - it is a 14mm pin instead of 12... I hope the FAE work was done, and I suspect that it was.
I am 'lucky' in that I am still learning the car - really only 2 seasons at this point, so I am not as fast as many (yet)...
Ray
Ray
#42
Ray
Ray
I do like Tarett as they make a lot of great products. Ira's service is top notch. They make very nice parts and I use their front extended drop links along with the rear DLs. The extended drop links are excellent. I do however wish that the quality of the mono ***** they use was better as they develop play with use. A few years ago I ran their monoball retrofit kit that I had installed in the stock LCAs. It worked well but again developed noticeable play after a single season (30 track days) which was frustrating. I've since swapped to the RSR arms and have several seasons on them. When I them checked last time, the German mono ***** were as tight as the day I put them on. Zero play, none... That was a wakeup call for me and a realization why going with the Motorsport parts was well worth the extra cost. Yes, they are more expensive but as the saying goes, you get what you pay for.
#43
Stress (and risk of failure) grows almost exponentially when stiffness, grip, and hp/tq are pushed beyond their intended ranges. When all three are pushed simultaneously the time of failure becomes anyone's bet. In that case, the most diligent approach would be to replace stressed components much sooner than even the most conservative expectations.
Smart to stick with Nittos until you come up with a stronger design/solution.
#44
^this
#45
I was going through wheel bearings at an alarming rate about a year ago and I think hub wear was actually a contributing factor. After replacing the hubs, axles and bearings all at once my bearing issues have gone away.
