Wurth Silver Alloy Wheel Paint Question
Has anyone used this stuff?
My question is how long must it dry before applying a clear coat?
I have Spray Max 2K that I want to apply as a final coat to the wheels.
Thanks in advance.
Thanks in advance.
DIY wheel repaint with Wurth spray was discussed years ago on the 964 forum - and probably elsewhere.
IIRC, generally favorable results with Wurth and some other rattle can paints, including one that needed UV to reach full color and cure.
Clear coat is part of the drill.
You'll probably find specific info on surface prep. etc using search.
In the end I never did it because I'm lazy and I had a track car.
Good luck
Good luck
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
I used it on my E88's last year and had great luck with it. I applied the clear coat a couple hours after the final coat of paint. The paint dries really quick! Good luck!
