Chirping noise from transmission / flywheel
#31
Yes, going on about 16 months strong on my chirping RMS. It's never changed in pitch, or volume, and importantly remains leak free. I am curious to this GT3 variant that is leak free. Maybe when a new clutch goes in when that time comes.
Thanks greatly for the follow up email!
#32
I also had the engine dropped, coolant pipes were welded, and rear main seal was changed along with all the belts. I also have the same sound and the car is running great.
#34
Technical Guru
Revival. Friend had rms changed on a 7-3. Developed Chirping noise. Apparently there is a Teflon coated vs non Teflon piece that sits under seal? Anyhow he's going to email parts of first and second rms. after second rms (new one is gt3 rms. last one 996 turbo rms) CHIRPING WENT AWAY.!! I still have my chirping since rms changed. Car running fine. 30 track days. Won't bother changing until next major overhaul. My chirping is not from t o bearing.
#35
Revival. Friend had rms changed on a 7-3. Developed Chirping noise. Apparently there is a Teflon coated vs non Teflon piece that sits under seal? Anyhow he's going to email parts of first and second rms. after second rms (new one is gt3 rms. last one 996 turbo rms) CHIRPING WENT AWAY.!! I still have my chirping since rms changed. Car running fine. 30 track days. Won't bother changing until next major overhaul. My chirping is not from t o bearing. It was changed. No change with rpm. Exact as video in thread Will update when I get part numbers Mk
#37
Technical Guru
Just got my car back from a RMS replacement (997 GT3 seal leaked last year, so had a 996 Turbo RMS installed under warranty this year), part number 999-113-426-41. However, I am now getting what I guess you could consider a chirping noise. Really difficult to tell where it's coming from. There's enough sound in the engine where it's difficult to hear it clearly. You can hear it from under the car, so that makes me think it could be the RMS as mentioned here. Does not go away when the clutch is depressed. When you apply load to the engine, you cannot hear it (probably because the rest of the car is so loud) but you can hear it when coming off load and RPM's are coming back down to idle.
I do plan to have my shop take a listen to it when I get time to drive down there (they're an hour away).
Two videos with the noise, linked. It's not the normal Mezger noise and rattles, it's a more hollow sound, sort of what I would consider sounding like setting down a plastic cup, or some sort of noise you'd make with your mouth (as weird as that sounds). First video is a bit better and you do have to turn the volume up quite a bit since it's in the background (it's difficult to hear over the normal Mezger sounds).
https://drive.google.com/file/d/1D5d...ew?usp=sharing
https://drive.google.com/file/d/1v2u...ew?usp=sharing
#41
Not positive, but I think the chirping is a vacuum leak past the RMS, does not affect everyone, and I am uncertain as to the fix. I updated mine with the new 997 and ring as described in a TSB. search on rbahr, I posted the TSB some time ago.
Ray
Ray
#42
Joe
#44
Just asked them to confirm. I noticed it on my invoice last year when they installed the 997 GT3 part. Didn’t notice it on my invoice from this year. Not sure if It’s reusable or not and maybe that’s why I’m not noticing it listed.
Either way, I’m going to have them listen to it soon and then will report back on any updates.
#45
as far as "is this chirp noise a problem"...I think many of us, myself included, have given it quite the test of time and come way with no issues other than the noise itself. Mine is still in the car from 2014-2015 timeframe and still chirping away but also still bone dry.
