Remote Lock Issues
For whatever reason my key fob remote lock/unlock seems to have lost significant sensitivity, almost as if the battery was exhausted.
I have gone through two sets of batteries (just incase one lot was a bad one) and both key fobs work poorly.
Sometimes I can unlock the car at 30' and others I can't get it to work even when the fob is right next to the car's windows (doesn't matter which window, I have tried all different positions).
In rare instances I am forced to unlock the door with the key.
Any ideas why this is happening?
Thanks.
Thanks.
Have u tried putting key fob underneath your chin and press key fob. Maybe the switch thingie is getting old. The other pair of keys is same thing? Mike
I do not know where the receiver is located in the car, but maybe there is an issue with its antenna or the antenna connection.
It just seems weird that I can unlock it at a distance sometimes and others it will not work even when you are right up against the car.
