996 PCCB questions
996 PCCB questions
Hey Guys,
Questions for you, will a set of 996 GT2 PCCB bolt directly up to a 996 TT? iv read all of these threads regarding the rotor hat offset being different between the two and it could potentially hit the strut housing..
If i bought a set of PCCB off a GT2, could i bolt them directly up to a 996TT?
Is there a difference between 996 turbo S PCCB and 996 GT2 PCCB?
IIRC, Turbo and GT2/3 use different offset discs/rotors due to front uprights being different, believe rear rotors share the same offset and should work...997Turbo steel rotors should fit all-round if you are open to steel conversion..
