Charging issues...
Charging issues...
The battery is brand new. Should I replace the whole alternator, have it rebuilt, or just replace the voltage regulator? Any input would be appreciated. Thank you.
Is it not charging at all? I would start with the voltage regulator. I had the same issue on my old 996TT, replaced the voltage regulator, and it was good to go. I don't remember if there is a way to diagnose alternator vs. voltage regulator but it might be covered in another post if you search here or 6speed. Also, regulator is so much cheaper than alternator.
I recently had a regulator issue and found that I could have the unit alternator rebuilt including a new regulator and warrenty for a little more than just replacing the regulator and no warrenty. I removed the alternator and took it to the shop for rebuild got it back the same day and installed problem solved cheap.
Probably regulator got my Alt. rebuilt on local shop for less than $100. Easy to remove and install.
Peter
Thanks for the info guys, dropped it off at my service shop and having the voltage regulator and brushes replaced. I usually do everything myself just don't have time these days...
