New camera mount pics
I've had the IO Port camera mount for a couple years now, but decided to try the KW Machine Works one. They come as separate cage clamps and screw-on camera mounts. Here I am showing a 1.5" clamp with a dual GoPro mount. It looks pretty nice, install was easy and feels secure. Hopefully the video will be smooth.
![](http://i983.photobucket.com/albums/ae311/crohani/996%20911%20GT3/DSC_0003_resized.jpg)
![](http://i983.photobucket.com/albums/ae311/crohani/996%20911%20GT3/DSC_0016_resized.jpg)
![](http://i983.photobucket.com/albums/ae311/crohani/996%20911%20GT3/DSC_0018_resized.jpg)
![](http://i983.photobucket.com/albums/ae311/crohani/996%20911%20GT3/DSC_0019_resized.jpg)
![](http://i983.photobucket.com/albums/ae311/crohani/996%20911%20GT3/DSC_0030_resized.jpg)
![](http://i983.photobucket.com/albums/ae311/crohani/996%20911%20GT3/DSC_0027_resized.jpg)
![](http://i983.photobucket.com/albums/ae311/crohani/996%20911%20GT3/DSC_0036_resized.jpg)
That looks good. I am a GoPro user and that might be an option for me in the future.
Hi all,
Firstly, apologies for resurrecting an old thread, although I have registered particularly to enquire about the above dual GoPro Mount.
Im looking to purchase the dual mount, although do you have an image of the underside of the mount?
Is it a standard tripod 1/4" bolt that bolts into the roll bar section?
I want to attach the dual mount to a standard GoPro mount, but am unsure of what adapter I would need in between since there seem to be no details on the underside of the dual mount an dhow it connects to other mounts - if that makes sense!!
Thanking you in advance.
Hi all,
Solid video, no issues, no vibrations. The only thing is you have to tighten the articulation bolts more than I thought. After my first session of use, I got out of the car and the camera had rotated from horizontal to vertical! I watched the video and I could see it rotate a bit at each hard turn. Tightened it up and all is fine.
The dual mount attaches to the cage mount with a screw-type attachment which I believe is KW-specific. Just like a bottle top. In the first picture you can just about see the screw thread around the perimeter of the mount base on the right. It does look like there's a hole that might take a camera mount bolt, but really it is nothing. I don't think there's any way to attach a standard single to this the dual mount. I will try to snap a picture later.
Thank you.
Thats great, thank you very much for taking the time to take the pic - I really appreciate it.
It looks as though the centre bolt can therefore be removed and the bottom round threaded part can therefore be removed to leave the bottom of the mount completely flush??
Or is that bottom part welded on?
Im wondering if the bottom part can be removed leaving the centre bolt free to be screwed to something else?
