996 GT2/GT3 Forum 1999-2005
Wheel studs
Old 11-22-2012, 05:54 PM
996FLT6
996FLT6's Avatar
Originally Posted by mooty
longer stud isn't why they break. the breakage is usually at the hub area. not all studs are designed correctly. it's more than just a stick with grooves on them. some are VERY expensive studs.
bolts have advantages and disadvantages as well. you can't ride wild offsets b/c the bolt isn't long enough.
FYI I know u can do -4.0 camber up front with stock 5 lug nuts : ). Mike
Old 11-22-2012, 05:55 PM
996FLT6
996FLT6's Avatar
Oh **** nevermind. Mike
Old 11-22-2012, 11:00 PM
powdrhound
powdrhound's Avatar
Received 1,892 Likes on 1,105 Posts
I've had RUF studs on my car for the last 7 years. I just changed them all out last year as a precaution. RUF sent me a new set and they are H&R studs which are available here in the US in various lengths and fairly cheap. I have never had a single problem and the car sees the track a lot.
http://www.flickr.com/photos/87731073@N06/8209273697/http://www.flickr.com/photos/87731073@N06/8209273697/ by http://www.flickr.com/people/87731073@N06/, on Flickr
Old 11-23-2012, 01:31 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,705 Likes on 2,342 Posts
offset, not camber.
some wheels have VERY thick centers. u need about 95mm studs and possibly longer than that.
Old 11-24-2012, 05:41 PM
KOAN
KOAN's Avatar
Does H&R make studs that will work with BBS E88?
Old 11-24-2012, 05:51 PM
FFaust
FFaust's Avatar
Had issues last year, and broke 3 on separate occasions. Took them all off and threw them out (they were only a month old).
Spoke to Apex, who told me that they had a new and improved stud coming this year, so I waited. Got the new Pro-Studs, and have not broken one yet.
Never did find out why they broke last year.
Old 11-24-2012, 06:09 PM
powdrhound
powdrhound's Avatar
H&R makes them in just about every length imaginable in 10mm increments. They do not rust and they come with thread locker pre applied. Great product....
Old 12-03-2012, 01:03 PM
ChrisFL
ChrisFL's Avatar
Can anyone post a link to quality wheel studs? Are forged studs overkill? Any good pointers for install? ( got the anti-seize part)....
Old 12-03-2012, 01:32 PM
rodneyr
rodneyr's Avatar
Studs are just another component to monitor and can break from user error or part failure. I have seem many cars over the years sidelined because one broke and are pain in the rear to get it out. The marginal benefit is not worth the risk and monitoring for me.
Old 12-03-2012, 04:34 PM
Vonschmidt
Vonschmidt's Avatar
Studs are just like the poster above referenced. They are a Motorsports item with cycle life and you never get more than you pay for. That said on our new GT2 AJ has selected studs due to cycle issues. Manufacturer is MSI racing products.
They are used in NASCAR and Grand-Am.
Cost is higher but as I seem to rember this is what holds the wheels onto my car at high and low speed turns, not a good time to scrimp IMHO
Old 12-03-2012, 04:50 PM
ChrisFL
ChrisFL's Avatar
I have not problem paying more for higher quality especially when it comes to keeping the wheels on the car... I just wanted to know if broken studs are because they aren't forged? the material? or installation error?
Old 12-03-2012, 09:42 PM
Vonschmidt
Vonschmidt's Avatar
Never intended to indicate that anyone was worry about cost. Instead I was stating that since so many seem to be having problems there are high end products that others might want to consider. Since these resources are sometimes difficult to find I was simply sharing the resource so each could consider options. In my case that just knowing the high end options are out there and used by pro teams makes me more comfortable with my choice.
Old 12-03-2012, 11:27 PM
philooo
philooo's Avatar
so is anobody gonna post a link and part number of the good one to buy ?
Old 12-04-2012, 12:06 AM
FFaust
FFaust's Avatar
http://www.race-studs.com/servlet/th...27-race/Detail
This is what I have. So far, so good... but who knows.
Old 12-04-2012, 12:07 AM
mooty
mooty's Avatar
CDOC used to have studs made by BBS. i bought a very LARGE quantity of those and stashed them.
not sure if CDOC is still around tho
Quick Reply: Wheel studs
