Rear wheel well wear
I am running 315 Nitto NT01s and I was surprised to see so much wear on the rear wheel well. These tires were new to start a three day event with co-drivers.
Both wells had wear but the lsft was worst. I am going to look for a smaller tire.
Fresh alignment:
Camber Left -1.89
Right -1.99
Toe Left 1.9 mm
Right 2.5 mm
Total Toe Rear 4.4 mm
Thrust Angle Rear -0.02
Sway Rear 1 off Soft
Weight Rear 0.50
Ride Height Rear 127
![](https://rennlist.com/forums/members/dudley-albums-tire-wear-picture16361-p1010149.jpg)
Fresh alignment:
Camber Left -1.89
Right -1.99
Toe Left 1.9 mm
Right 2.5 mm
Weight Rear 0.50
![](https://rennlist.com/forums/members/dudley-albums-tire-wear-picture16362-p1010154.jpg)
Can you post your rear wheel offset specs? I bet they are inset too much.
My alignment specs are very similar to yours, maybe even a little lower, and I have no such wear, and this is on a wheel with identical to stock specs.
Admin
Had the same issue with 315 PS2s. stock ET 2deg Camber.
888 315s are narrower with no rubbing.
In both cases a 3-5mm spacers set worked perfectly.
Keep the tires.
J
Keep the tires.
J
I did not think of spacers! Of course.
I am running cheap O.Z. Alleggerita HLT
Rear Fitment
18x11, OZ PORSCHE CAP
Offset: +63mm
Backspacing: 8.50"
Bolt Pattern: 5-130
Rec. Tire Size:295/30-18
Weight: 20.4lbs.
Rear Fitment
Offset: +63mm
Backspacing: 8.50"
Bolt Pattern: 5-130
Weight: 20.4lbs.
