Missed Shift = Bent Valves?
#32
Here i went not from 3rd to 4th but from 3rd to 2nd. Auch.
After this mis shift i consequently shift 'back handed' into 4th. You can see i pulled it too much towards me too much rather then straight down. Luckily the entire engine was 350$ to replace.
ha ha
Here you can hear how it sound if you really mis shift .. Engine completely dead afterwards.
ha ha
#33
Typically, you get bent valves from an overrev because the valve springs cannot keep up with the rpm of the motor. So before the valve is back in the combustion position, It gets whacked by the piston coming up to compress. Or you break a timing chain/ belt and the valves are out of phase with the piston coming up. And I would like to go against the grain here and tell you to enjoy your 4 liter with the 996 cams. Swapping the cams will give more power but you can expect a bunch of problems that you will spend a lot of time and money sorting out. Enjoy the car you have!!
#34
As an observation, think you're more likely to make a miss shift changing UP through the box than changing DOWN, therefore folks in left hand drive vehicle's are more susceptible to that mistake than folks in right hand drive as you're pulling the stick towards you for a higher gear but then hitting a lower one. (a right hand drive is always pulling towards a higher gear)
#35
ha ha
http://www.youtube.com/watch?v=PJPxxMfVLuQ
ha ha
#36
#37
In this case, the focus is not so much focused on the leakdown values, but how they relate across the cylinder banks.
Finally, I'm hoping the #3 test result was in error.
#38
With regard to the plenum not seating into the rubber sleeves/ tubes that far, I also made that observation when I split all of that apart to get my coolant fittings off to be welded....or when I was putting it back together actually. That's probably why they come apart easily when you spin
Glad to hear its back up and running.
Looks like you were in 2nd and tried to go to 3rd but ended up on 1. That's not all that bad. We're you provided a leakdown test prior to buying car? I was far worse then u in the misshift category but since engine is upsized I don't know how tite the tolerances are for over revs. Mike
ha ha
ha ha
Back-handed is definitely the way to shift in to 4th and is the way I do it or at least try to every time (looking through my vids though it seem as if I do).
The 997 GT3 street intake cams really wouldn't cause any problems although I would definitely get it re-tuned. Where you run into more issues / money is when you go to a cam without Variocam as you have to make some other modifications to the cam housings. And of course you have to know exactly what your tolerances are and the exact spec of the cams to avoid any clearance issues which is a path I don't really want to go down. And in reality, I probably won't be doing cams anytime in the near future if I don't have to tear into the motor to get the current issue solved (which I'm feeling like I won't at this point).
I undestand the typical test procedure. When you have consistent readings throughout 5 cylinders and the 6th is 10-15% greater, that raises a flag.
#39
My engine is getting dropped for same reason as we speak. Try spraying carb cleaner on affected hoses when car running preferably when engine is cold(have a fire extinguisher just in case). If it changes idle due to spray its leaking. I'm replacing them with new ones hence the reason for engine drop- its 8 yr old rubber. Mike
#40
#41
Sure did. One hose (driver side) was sealed as possibly can when it popped but still car was sputtering like ****. Sprayed carb cleaner on the resealed one no change in idle.Sprayed the other hose(passenger side) which looked sealed to me idle smoothed out. I can see another hose behind the affected one. Not sure how many hoses there are but when engine is dropped I'll definitely replace them. Can u keep a steady idle at 2k when u press gas or it's hunting up/down at this point? Mike
#42
The ecu will try to rich up the gas mixture due to the lean condition with the vacuum leak. Talk about smell of unburnt gas. If it fully popped out it wont even start. Ecu can only add so much fuel to get it to combust. It was a chore to get car to tow truck since tow truck can't fit in the narrow alleyway where my garage is. I was keeping revs at 6k to keep it from stalling- nasty sounding ie sounds like engine going to grenade. Mike
#43
Car is backing up and running! I dropped the motor a couple inches and found that the top hose directly behind the plenum had also come off slightly which is also the reason it was so difficult to get the hoses on each side of the plenum seated properly. After reaffixing the hose she started right up and settled into a nice idle. Took her for a drive this weekend and everything felt normal. I'm still going to run another compression at leak down at some point here but for now I'm just relieved that I have a living car again! Thanks again guys for all of the help!
#44
Woo cheers, she runs again
Dan Kennedy
SharkWerks: www.sharkwerks.com
Northern California's Porsche Performance, & authorized Evolution Motorsports, TechArt, HRE and Tubi, Cargraphic dealer and installation center
Phone: 510-651-0300
Email: dan@sharkwerks.com
SharkWerks' Latest Updates on Twitter
Dan Kennedy
Phone: 510-651-0300
#45
Motor has been dropped. Damn there's lotta hoses involved with intake plenum. One cracked almost in half and the others are old/hard. Need to replace them all(i see 7). If u guys drive them I don't think u need to worry. Mike
