Educate Me on Suspension Links
Does PMNA make adjustable dog bones and toe links similar to what RSS makes?
My experience with aftermarket suspension parts has been less than stellar, with the heim joints wearing out quickly.
sounds like PMNA bits are the way to go. What are prices like compared to say RSS?
You're saying adjust camber via the LCA, correct?
Oh god no. The most important first piece you should add to the car. Get the locking plate kit as well so you can lock the settings in without possible eccentric changes under load.
Not the locking plates. But the rest you can get from PMNA. It's just a steering rod with a thread adjuster and a proper mounting joint. Just go with the Tarett set (THESE or THESE if you plan to bump steer the car with a ride height adjustable suspension)
Make sure to get the locking plates as well.
+1 to Dell's comments. I agree with his PMNA comment as well, but the independent vendors exist because they charge LESS than PMNA.
A great example of this is rotors... This is why so many 996GT3 DE guys have moved from the front, cross-drilled PMNA cup parts to after-market brands for the Cayenne... $500/rotor versus $80/rotor is a huge cost savings...
Per Dell's last post, I went with Tarett and their locking plates in 2006. Not a problem since... Now my car has gone squirelly into the corners of late - but it was not my accenture... Damn LSD needs a rebuild!
-B
-B
Anyone have the part number for the PMNA mono all dog bones? These would be perfect as I don't want the threaded kind. Also, is it possible to replace the Oem dogbone rubber bushings with mono *****? That would be most economical.
So it sounds like there is no negative feedback on GMG and the rest of the aftermarket stuff has mixed reviews. Does that sound accurate?
Also, isn't there something online with the full PMNA catalog? Seems like these parts are somewhat hard to get. I would think PMNA would be happy to sell them to the public as they likely have a nice mark up.
