Where is my Oil Pressure Sensor Located?
I have an intermittent fault with the oil pressure gauge where it throws a fault stating there is a faulty sensor.
The gauge will drop to zero suddenly, throw a fault, and then suddenly begin working again normally.
It started when the car got wet a few months back and I suspect that either the sensor is bad or more likely the wire connection to the sensor is oxidized.
Where is this sensor located?
Thanks in advance.
Thanks in advance.
Just replaced mine - its located horizontally on the RS
10 minute job, 48 quid in the uk from ebay Porsche-Apart delivered in less than 24 hours
Note that the GT3RS version is fitted horizontally to the end of a metal tube with a bracket and it is much easier to fit a standard 0.75 inch spanner on it.
http://www.flickr.com/photos/83374345@N00/7261235864/http://www.flickr.com/photos/83374345@N00/7261235864/ by http://www.flickr.com/people/83374345@N00/, on Flickr
http://www.flickr.com/photos/83374345@N00/7261237106/http://www.flickr.com/photos/83374345@N00/7261237106/ by http://www.flickr.com/people/83374345@N00/, on Flickr
http://www.flickr.com/photos/83374345@N00/7261236290/http://www.flickr.com/photos/83374345@N00/7261236290/ by http://www.flickr.com/people/83374345@N00/, on Flickr
http://www.flickr.com/photos/83374345@N00/7261237862/http://www.flickr.com/photos/83374345@N00/7261237862/ by http://www.flickr.com/people/83374345@N00/, on Flickr
http://www.flickr.com/photos/83374345@N00/7261238262/http://www.flickr.com/photos/83374345@N00/7261238262/ by http://www.flickr.com/people/83374345@N00/, on Flickr
At tick over
http://www.flickr.com/photos/83374345@N00/7261558004/http://www.flickr.com/photos/83374345@N00/7261558004/ by http://www.flickr.com/people/83374345@N00/, on Flickr
at 3000rpm
http://www.flickr.com/photos/83374345@N00/7261558794/http://www.flickr.com/photos/83374345@N00/7261558794/ by http://www.flickr.com/people/83374345@N00/, on Flickr
At tick over
at 3000rpm
