x-post: GT3 Air Duct for Transmission
Good question... Is that a standard piece on our cars? My car did not have it and I bought one shortly after purchase. I've seen some GT3 while doing DE Tech inspections with it missing.
The "air diverter" has a couple of scoops that flow air to each side of the trans. It mounts on the cross member (see pics) via plastic tabs and the forward edge attaches to the trailing edge of the big under car panel (see screw in picture)
Hope the pictures help... Should have take a picture of panel when I had it out for a trans oil change... Hope this helps! Lou
Just took these pictures. One shows tabs attaching it to cross bar. Other shows air scoop. I believe the low pressure under the car will flow right into the opening like a ram-air effect.
I used two blind nuts, a couple of screws and washers. See pictures. The real question is, did they come from the factory with it? Or were they tossed out by the service department? Survey says?
I have installed it.
Parts number and prices are the following.
996-504-529-02 : Air duct(x1) : $36
999-507-348-01 : Speed Nut(x2) : $1
999-073-061-02 : Tapping screw(x2) : $0.75
944-503-255-00 : Spacer Sleeve(x2) : $3.25 <=strong recommend parts
![](http://cdn.mkimg.carview.co.jp/minkara/note/000/001/963/164/1963164/p6.jpg?ct=a85b569b2132)
related information:
http://minkara.carview.co.jp/userid/...3164/note.aspx
