RSS 930 Rollbar/ Half-Cage Is In
Dell is getting my Teq bar, so I decided to pull the trigger on this RSS bar. Mike S. @ RSS was great to work with, and Leith Porsche in Cary did all of the work, including remounting my camera (with rubber lips on the mount so as to not scratch the bar) and the factory seat bracket modification.
I have some aluminum shaft collars on the way as well from McMasterCarr to keep the shoulder haress straps located correctly. (link)
Looks like they did a very nice job with the holes in the rear carpet shelf. Makes me want to buy a new piece and try again.
Do you have a detailed photo of what they did with the camera mount to avoid scratching the bar?
Thanks,
Mike
Thanks,
Mike
U can use same color duct tape to mount on camera mount wo scratching paint- cheap!!! Duct tape and zipties- greatest inventions ever. Mike
http://www.mcmaster.com/nav/enter.asp?partnum=6436K75
But you should not need them for the Teq bar - that's what those rubber rings do....
Search on p/n 6436K75; Two-Piece Clamp-on Shaft Collar, Aluminum, 1-1/2" Bore, 2-3/8" OD, 9/16" Width
