Under Steer
Under Steer
My intial experience with the car, I wore though a two sets of rear tires for each set of front tires. I bought a new set of rims and put on the Nitto NT-01s
I then had the car re-aligned. These tires are all wearing at the same rate - all four are about to cord.
Would this indicate an alignment that promotes understeer?
Is this a good thing?
Admin
+1 what are the (new) alignment specs?
with stock alignment the R/F ratio is about 2:1;
with a proper alignment is closer to 1:1 than 2:1
(with 888s and MS cups and PS2s)
and btw understeer is not to be judged by tire wear..
Here are my alignment specs:
Front Camber: Both Left & Right -2.5*
Front Toe: Both Left & Right 0
Rear Camber: Both Left & Right -1.9*
Rear Toe: Both Left & Right 2 mm (in)
Sway Bars: Front - 1 from full soft
Rear - 1 from full soft
The tires are wearing evenly but the outside edges are nearly corded.
Hot Pressures are 33 psi front and 38 psi rear.
Tire surface temperatures are:
Outside Middle Inside
Left Front 131* 144* 145
Right Front 133* 142* 144*
Left Rear 153* 163* 172*
Right Rear 168* 173* 181*
