RS bumper upper radiator slots
#106
Nick, your attention to detail is amazing. Maybe we can "subsidize" one another by doing some projects twice at the same time - I'll haul mine up to FOCO, and watch your surgical magic...Great seeing you last weekend!
Nickshu (09-27-2019)
#107
I finally got around to doing this conversion on my front bumper. After blowing a coolant hose at the track my car is at the shop getting a bunch of stuff done on it so I brought the bumper home to make the cutouts. Worth noting that I found the templates to be small compared to the actual measurements posted earlier here so I made my own templates. I cut the areas out with a Dremel tool using a plastic cut off wheel, did the end curves with a Roto-zip bit, then smoothed/finished the edges with a sandpaper wheel. I only had one little "oops" with the sandpaper wheel which you can see in the photos (darn). I used the cutout pieces from the bumper to "emboss" the aluminum mesh then tacked it in place with hot glue followed by Locktite plastic bonder epoxy. The mesh I used was from Amazon and is for motorcycle radiators. I painted the cut edges with a silver paintmarker before installing the mesh (worked/matched surprisingly well). I then used a piece of urethane type plastic I found around the house to block the lower holes and bonded it in place with 3M Window-weld urethane adhesive/sealer. I'm pretty happy with how it came out, especially for a freehand cut out. The shop is installing the GT2 radiator duct and flipping the radiator (going to all aluminum radiators x3, should be nice) before reinstalling the modified bumper. Can't wait!
Here's the mesh I used which I was very happy with: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#108
Here is some more information for the knowledge base on this.....996 Cup cars have NO ducting behind the center radiator. None at all.
This past weekend I was at VIR and had a chance to see a 996 Cup car that has 1000 original miles and has never been raced. It is owned by a Porsche dealer and has been used as a dealer demo/showroom car since new, only used at the track to drive politicians and celebs around for demo laps. So the car is all original and untouched. Some of you may know this car, I believe it's owned by Euroclassics Porsche in Richmond, VA.
I looked at the top- exit center radiator setup and was surprised to find there is NO ducting at all. Just the front duct between the air intake bumper opening and the radiator, and of course no exit slots under the bumper. Airflow just finds it's way up through the top of the bumper on it's own w/o any duct. This explains why in the Cup car center radiator diagram posted here there is no mention of any ducting behind the center radiator.
Here are some photos I snapped of it:
#109
Hard to see in the pics but is the center radiator canted forward on the 996 CUP?
#110
Yes it is. From the 2005 Cup car manual: Note the 'R' alongside of part #6 - the standoff. The designates a Porsche Motorsports part (as opposed to the factory street car)
Ray
Ray
#111
Some pics of my 996 cup sans front bumper. As per 2nd pic, there is only a very slight lean forward for the center radiator. As you would expect, this set up works very well. Coolant temp never goes above around 85 deg celcius when out on track going by my motec data. Tbh I’m not sure why you would need a duct as area behind the center radiator is quite well compartmentalized already. There would perhaps be minimal escape to the sides of the center radiator, however I feel the front intake ducts for the side radiators would further minimalize this. My guess is Porsche did the center ducting for the GT2 because of a) higher HP output requiring more cooling and b) water cooled turbos placing increased strain on the cooling system.
#112
Then, as you know, the Cup bumper has no openings on the bottom so the only place the incoming air can go is upwards out the top of the bumper.
#114
It looks like it bolts to the top of the duct? does it direct air down into the radiator away from the mating surface between the radiator top and bracket #3? I'm speculating based on the pic..
#115
Spiller: your center radiator does look a little like it is leaning forward - could be the lens...
Part 14 looks like it bolts to the top of the rubber duct... Probably a bit more support for the radiator
