RS bumper upper radiator slots
#61
The template i took from OZ951
http://www.oz951.com/public/emmypics...ate_emboss.bmp
There is a bunch of interesting stuff on his site
http://www.oz951.com/public/emmy.htm#OZ951
Thanks OZ951
Thanks OZ951
#64
Thanks OZ951
Thanks OZ951
#67
starting my radiator tilt (flipped upside down, cut rubber version), under-bumper hole coverup (downforce boost) and mesh (black) grill-fit now. Got a nasty ding from a coin sized rock in the rad which then filled up with dirt and insect goo. I can imagine it wont take long to get worse cosnidering all the wind down here! Yes, and as you may have noted, these are the cheapest mod's you can do, beside the ultra-secret crankcase breather (which has still to be 'approved'). Slowly slowly catchee monkee style.
Just before I plunge in, Thanks for all the detail especially SLOW, OZ and D-uber (aha! now I get the tripy avatar ) whichmakes this all much easier and thus fun!
Baseline: Car was running 82-3 degrees although that is optimal - will see if any changes notably. Hoping it comes from the DF side.
Must do this all this week as 997 thrott body and K&N filter arrived and also sent exhaust off for the cat removal/bypass pipes so next week will be busy! What slope, where?
Gents ...
Gents ...
#68
Gents ...
Gents ...
I read the breather thread years ago, I wish someone here had long term experience to report with it. Honestly that's one I'm probably not going near because the last thing I need is my car leaking all over the place.
#69
I'd like to but no proper dynos handy near me. I've run pretty consistent laps around my track for 6 sessions ie top times are all within .3 so I know my times and with my SOLO I have 20 or so 0-160 kmh runs which I have downloaded. Ave of top 5 runs was 1.99s to 60, 5.74 to 120, 9.41 to 160 all with just filled tank and warm bridestone semis. I also run with a guy who has a non RS 6 with all these mods (and a lighter exhaust and tuned ecu) and he just pulls away on the straights, so those will be my benchmarks.
John said he thought you could widen out the 6 plenum yourself and have same impact - he sounded pretty convinced so there must have been a few tests. I'm going to do all this air flow/breathing stuff first, then let it settle before doing a tune in a few weeks or so. maybe tweak the wing with the shims too.
I'm checking with an Italian pro cup mechanic who'll be here for their off season soon before I do the breather but I think it sounds good for the RS re seals already in place etc...
#70
Admin
Excellent posts and aero work in this thread. Congrats to all!
The IPD plenum is unnecessary and doesn't work as advertised.
Since I established this fact, If I find the time, I want to dyno the larger TB with the modified stock plenum and compare results. I am curious.
Serge did the right thing and modified the stock unit. Technically, it was my idea but he implemented perfectly.
Regarding the breather, I am running it for some years now and I have some thoughts in the following thread; anyone that has something to add or can correct me please feel free to bump it.
https://rennlist.com/forums/996-gt2-...-worth-it.html
post 22
if you want the short version, this is not a must have item..
..on the other hand the ram-air scoop is. (The gentleman with the white/red car has that already..)
Best,
post 22
Best,
#71
I happen to be very familiar with a yellow car that also has the scoop
Back to the front bumper talk...this thread has me seriously considering that too now. I need track seson to start so I can stop thinking about modifying the car and just start driving it again.
#72
Thanks John - helping me save on unnecessaries and buy more Sunoco GT special
You guys mentioned 4LSerge .... But have you seen/heard much from him since he put the power plant back together? What ever could he be upto?
I shd add that I saw a guy w a 6RS ram air scoop add another piece of CF to the back of the intake to make the scoop that's catching the air about 2x higher than mine. ever seen that? Will post pics next time I see it.
#73
Admin
You are welcome.
Serge is getting married so he is kind of busy preparing the bachelor party. I am the technical consultant.
Post pics of the mega scoop although that sounds more like an air brake
#74
I knew the Avatar blank meant serious plans were afoot! I've no doubt Mooty or Mike can be relied of for ... ideas, but that might be properly OT.
