Brakes swap - lost one damper
I replaced the front PFC-06s with 01s and in the process I lost one of the middle damping plates. The problem is the little spider clip thing that seats in the caliper broke off and I couldn't get it out of the piston. (it was the middle piston)
I usually remove the dampers altogether, but they've survided this long so I left them in. So now I have 2 dampers and the middle piston doesn't.
Anyone see a major downside to this? I have the ability to grab a new set before my track outing this weekend, but I'm not really seeing the need.
I also forgot how loud these things were on the street. For the first couple miles they sounded like they were chewing up the rotors, and then they just went into squeak mode.
-td
-td
I wouldn't expect a problem. However, I have never used the spiders. Will the middle piston press directly on the pad backing plate? If so, there should be no problem.
I'll be switching back to 01's from 06's in a few weeks. I'll be eager to hear your impressions.
By damping plates can I assume that you mean ceramic isolators?
If so, I would not drive without them unless the pads are new, which they probably are in your case. As the pads wear, and the pistons come out of the caliper, I would be worried about the piston without the puck coming out too much and leaking or jamming.
A great pad, easy to use - no bedding required and stops like tossing out an anchor.
-td
I have heard that they are difficult to modulate, which is what I think I hear you saying. When I was using Pagid blacks, I didn't have that problem, but bedding is an art with them. So many options...so few opportunities to test...
