WTB: Schroth GT3 Seat 6-Point Harness
I have gt3 seats coming soon and I was wondering if anyone had a Schroth GT3 Seat 6-Point Harness for sale
I only need one, if possible the 2" Hans compatible but will consider the 3" version as well.
Just buy new; whomever you run with will likely have a expiration date requirement, and you'll have to pull them and buy new in a year anyway.
http://www.suncoastparts.com/product//PROFI2GT3.html
or the Porsche 'factory' Scroths
http://www.suncoastparts.com/product//6point.html
Also, PCA requires equal restraints (link) - you already have 1 harness set installed? Maybe you aren't running wtih PCA, but again check with your sanctioning body first for restraint requirements.
Just trying to save you the headache of buying, then rebuying, rules, issues, etc.
HTH
HTH
If I recall correctly, the only option you can get with the OEM Schroth belts is red and 3" shoulder and push button release (don't like that). However, you can order the Schroth harnesses (non-OEM) in blue, black, red, and silver with and combo you want as well as get the better camlock style attachement. I have run several different options from Schroth and while the Profi II-HANS setup is the most popular, my favorite is the Endurance Belt system. LINK
Thanks for the heads up, very interesting/important indeed ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I see that all harness, except gt3 specific, come with a specific 'fast clip buckle' in the end of each strap. Is there any advantage to use that system, I assume that it require a couple of additional hardware bits (BK loops).
I think I'll keep it simple and take the gt3 version as I have the gt3 seats coming but wondering about the pro and cons. I read a bunch of post already but I don't think I've read anything about that particular aspect
The OEM schroth GT3 betls have the eyelelets attached so you can use the mounting blocks on the side of the seats. I do NOT like that method. I prefer to mount to the chassis (either the bolts for the seats rails or the bolts for the 3-pt shoulder belts.
Interesting point again, it makes sense indeed to trust the chassis bolt and not the seat strength in case of a crash. Weird that porsche made it that way. so I assume I would need both of those thingy then
for the door side
![](http://www.bkauto.com/porsche/images/R-9004.jpg)
and those for the tunnel side.
But also it seems the gt3 harness is a tad more expensive so that should be about even.
BTW any advice about hans type or not ? I mean I want to get one but might not do it right away. Is it safe to run with the 2" hans top belt..without the hans device ? ... I can smell the answer.. but I figured I'd ask
![](http://www.bkauto.com/porsche/images/R-9003.jpg)
for the door side
This comfort level / safety horse discussion has been beaten to death many many times over; try a Search.
For non-racing applications, usng the stock mounting points for the stock /Schroth harnesses is adequate, *IMO*. The factory thinks so, a professional race engieer communicated same, and a Porsche certified technician also held the same opinion.
Think about it - if you are in a wreck strong enough to rip the seat and rails out of the floor, the belt mount points aren't going to matter much at that point. The only points connected to the chassis are the lap belts. The should belts are of course attched to the bar, and the substraps are attached to the sub strap bar, which of course is attached to....wait for it....the seat rail.
Having said that, (
) the last time I had my driver seat out for professional work, I had the BK mounts installed for the lap belts; a 'while you are in there' kind of thing.
Having said that, (
Admin
Having said that, (
Having said that, (
Bravo!
ONLY USE OEM PORSCHE / RECARO rails if you are planning to use the side mounts for the lap belts.
They are tested.
Recaro doesn't allow this method in their other double locking slider series..
Cheers,
Do people still run harnesses without a HANS device these days??? This is one of the most important add-on pieces of the safety system. I would NEVER get in a car without one that has a harness setup.
