(SOLVED- Fuel pump hose failure) Trouble holding idle and won't rev?
Interesting info Steve!
Fellow Rennlister Coochas is also having related engine woes. His car won't rev up and presently thinks he has a bad MAF. He ended up fueling up in Renfrew, as Mumford was out of fuel altogether.
What time did you fill up at or when did the tanker show up on Friday?
I fueled at 6:30am.
I fueled at 6:30am.
Dealer got back to me...
Gas is clean.
Fuel pump hose is split as per other threads have documented !
Looks like we continue to find that we have a known weakness in this fuel pump hose.
Anyone have access to the pricing of a new fuel pump pn 996 620 057 92 before I get HOSED by dealer?
They won't do the SAAB hosing solution.
Gas is clean.
Admin
Gas is clean.
Gas is clean.
euro PET price
I fueled at 6:30am.
I fueled at 6:30am.
Another documented fuel pump hose failure !
Got the car back and all is fixed.
Fuel pump failure... the little hose that has caused issues to others in the past is the culprit again.
Shelled out the cost for the whole pump assembly instead of the less expensive fix replacing only little hose from SAAB.
Here is the picture for my pump/hose issue...
![](http://i53.tinypic.com/2w50vuf.jpg)
