996 GT2/GT3 Forum 1999-2005
Steering Rack Problem?
Old Apr 22, 2011 | 11:13 PM
92tsiawd's Avatar
92tsiawd
Default Steering Rack Problem?
I have a 996 GT3, there is about a good 5 to 10 degrees of dead spot free play in the steering. When I was cruising on the highway at 75 mph, I held the steering wheel with both hands and the car would pick a slight change of direction and go there depending on the road/wind conditions. It then prompted me to do a slight 5 to 10 degree shake of the steering wheel and there was no change of direction. I was wondering if it could be that the steering rack is shot and needs a rebuild. Anyone else ever have a problem like this?
What's been done before is the car just had a corner balance, I was actually just driving home from that. Also had all the steering components, bushings, control arms, trailing arms checked by two shops.
Old Apr 22, 2011 | 11:24 PM
92tsiawd's Avatar
92tsiawd
oh and to add to this, the tire pressures are set correctly. Anyways, the sensation is that it feels like the car is wandering. The higher the speed, the more it does. At the track, above 120 mph, the car feels like it has a mind of its own and is pretty confidence deflating. I road race regionally and I can tell you the front end of the car feels loose
Old Apr 23, 2011 | 01:01 AM
996FLT6's Avatar
996FLT6
Alignement is 1st to check. My car was already off when bought off showroom floor. What are your alignment specs? Mike
Old Apr 24, 2011 | 05:50 PM
Dan Jacobs's Avatar
Dan Jacobs
Make sure the steering rack bolts are tight. I've seen many loosen (and a few fall out) The symptoms are exactly what you're describing. At my shop we loctite/torque them as part of regular maintenance
Old Apr 28, 2011 | 05:02 PM
GT3 Chuck's Avatar
GT3 Chuck
+1^ if you had a corner balance they had to do an alignment and part of that is centering the steering...if they didn't tighten it all down afterward it could just be loose...don't drive it that way
Old May 1, 2011 | 07:56 AM
StevoUK's Avatar
StevoUK
I had free play on my GT3RS wheel - stationary with engine off - the fault was a steering rack bolt loose. Get it checked.
