Weights on Brake Pads? Requirement?
So I've got the GT3 at the shop and they are working on the brakes, looks like the worn down set on there as a set of weights on the pads and the new Pagid's do not. Any danger is running without the weights on the new set?
Great answers guys thanks, my only other question is....is there a way to secure the weight so it doesn't fall off? The other pads had the weights tight and pressed in but this one was loose
remove the weights unless you are seeking what Ford used to tout in the Pinto with epic marketing savvy: Ground Hugging Weight
Nope...
