brake pin torque setting
Hello folks
I need to replace the front pads on my 2001 GT2. Does anyone know the torque setting for the bolt that secures the brake pad pin?
Many thanks.
Many thanks.
Admin
2001 GT2 PCCB
1. Before installation of the brake pads, check the wear of the brake discs
2. If necessary, press back the piston to its original position using the resetting fixture.
3. Fit new damper plates in the pistons. As the vibration dampers are provided with a protective film, the protective film must be removed before installation.
4. When fitting the vibration dampers on the small pistons, the cut-out on the vibration damper -arrow- is to be positioned at the brake pads guide pins as otherwise the vibration damper will be deformed!
5. Insert the brake pads.
6. Fit new expanding spring and new retaining pin with a new screw on the brake caliper! These parts are available as a repair set and must be renewed each time the pads are changed. When tightening the screw, counter at the retaining pin! Tightening torque of the screw = 25 ± 3 Nm
7. Insert the warning contact wire and warning contacts.
8. Firmly press the brake pedal several times to position the brake pads on the brake discs.
9. Check and, if necessary, correct the brake fluid level.
