Oil change in a pit questions
You think your car has a great 0-60 time....wait until you see the drain time of the tank ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I will definitely share with you for your second. I really want your first to be special![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Please make sure to have video rolling.................
Neat trick. Depending on how far into the pit my oil pan will be, I might try this.
Recap - There *will* be splashing, especially using a pit.
So my method will be:
1. Drive car over pit (no jackstands).
2. Place oil pan on support as close to the drain as possible (perhaps using bottle trick to avoid splashing)
3. Place cardboard/plastic bags in areas I think might get oily.
4. Perform oil change
Agreed?
Agreed?
Okay, so I just performed my first oil change on my new (to me) 996 GT3. Yes there was some serious splashing of oil. It's been over a year since Dell promised to share his no-splash technique, and I'm hoping for some insight.
The key is the inside of the oil drain. You want to go to a home improvement store (Ace, Lowe's, etc) and pick up one of those CHEAP air filters. Cut it in the form of a circle that will be inserted into the oil drain. The beauty of this method is that when the oil hits the filter is passes through b/c of the porosity but it splashes very little b/c of the dissipation of the oil across the filters slight resistance.
GT3 player par excellence
fancy catcher dell has
I put car on stands
rip open garbage bag, static will keep them stuck to floor
then let her gush
I need some excitement!
then plug back up. pull bag out (pans are on bag)
roll bag up and clean floor
oh as for me, I just h ad a sensual oil massage with 0/40
and a new pair of custom spotted highly rare limited edition Costco sweat pants.
YMMV
have a ball
I put car on stands
then let her gush
YMMV
have a ball
