Inboard Lap Belt Clip Point
I'm using Pole Positions and want to be able to clip the lap belts in and out. The BK long tunnel side mount is essentially unreachable so that if I get the belt clipped in, I'll never get it out. Is the best option to mount an I-bolt on the tunnel behind the seat?
If you are using the long inboard clips there is a problem. Have used them LOTS of times with no issues. They essentially should be at the same height as the stock seat belt receptacle. Think maybe you have the shorts.
