front air cup ducts
#31
I have read that the 997.2 rear brake ducts work on the 996 as well. But have not seen people installing them yet.
http://www.carnewal-europe.com/cpx_p97078.htm
(see the description that it would fit the 996..)
I have those but never fitted. (See here for details http://www.6speedonline.com/forums/9...e-ducts-4.html, bottom of page).
You have to cut away at the backing plate otherwise the air won't get to the disc. I attempted the install but decided to wait until I next remove the discs so it's easier to modify the plate. Plus, after considering it I really don't thing I'm putting that much heat into the rears to warrant them, fitted much cheaper/ smaller GT2 rear ducts. Oh well, more money in parts just sat on the shelf...
part#s
997 575 531 90 Air duct x1
997 575 532 90 Air duct x1
997 575 631 90 Support x1
997 575 632 90 Support x1
999 073 516 01 Screws x4
#33
I thought Porsche only made 1 type of rear ducts? I guess that's not the case? (You mentioned the much cheaper, GT2 option)
Edit: Never mind, I went to the 6-speed post you linked.. Looks like there is a 996 GT2 rear brake duct.. so I guess it is the 996 GT2 vs. 997 GT3/2 rear duct...
part#s
part#s
#34
WRT rear ducts, check your under carriage. You don't have the air leads that will collect air into the rear ducts. The underbody of the 997 is a bit different. If you install the rears you might not see any airflow different to the rotors. I think the 996 GT2 has these as well (both rotor ducts and venting).
I will try to dig up some underbody pics to illustrate.
-td
-td
#35
-td
-td
#37
I found this thread some time ago and just bought a pair for my car. Looks like they are from a 997 TT.
http://www.renntrack.com/forums/show...stalled&p=7628
Another option and they were like $15 each... Did not install them yet. Waiting for TRG brake lines... Lou
#40
#41
