996 GT3 - Rear bumper removal
Admin
Jason what did you buy after all?
John
ps. your instructions
look picture and:
1. remove 4 screws and cover
3. remove screws both sides of bumper
pull out bumper
14. disconnect plug of licence lights
15.16.17.18 remove heatshields
John
look picture and:
pull out bumper
there is a very good DIY on the site. Picture and all. It is pretty easy and you will use less foul language if you remove the cover. Especially if you do not have a lift.
Updating this old thread for the rear bumper removal since I just did it on a 996 GT3...
1. Remove top 4 screws and metal cover (medium Phillips).
2. Remove 3 bottom screws (small Phillips).
3. Remove 2 screws from bottom of each sides (T30).
4. Remove 1 screw from just inside the wheel well (easier with wheel off) for each side (small Phillips). I used a ratchet with a small extension and Phillips bit to avoid removing the wheels.
5. Pull out bumper cover out
6. Disconnect license plate light plugs
brontosaurus (06-28-2021)
I removed the rear bumper this weekend but could do all I needed to without disconnecting the license plate lights. For future reference, however, how do you disconnect the plug #14 in 911Slow's post above? There is a tab on it but neither pushing or pulling made a difference (didnt really force as didnt need to disconnect, so if it is elbow grease just let me know...). TIA!
9A700751700 is what i see as the new number for the 6 screws on the l&r side of the bumper
99907322709 old #
90007534001 new number for the rear bracket that goes from the bumper to the heat shield.
99907504802 old #
I got these numbers from the autoatlanta site 996, not the gt3 drawing as they should be the same. Just check the gt3 page and the numbers r the same.
99907322709 old #
99907504802 old #
brontosaurus (04-07-2024)
