anyone have a spare transmission (manual) for 03 996 tt?
anyone have a spare low mileage manual transmission kicking around?
how can i be assured that the unit doesnt have a 2nd pop out issue?
if it turns out to have the issue, how does one fix it? is it simple?
I have a spare tranny for an 02' C2.. Not sure if it is the same as a turbo though? Condition is good but I'm going to have my shop look through it to see if anything needs done prior to selling. PM me if interested..
C2/C4 and Twin Turbo gearboxes can't be swapped back and forth between cars. It has to do with the bolt pattern on the crankcase. The engines are different and mandate a different bell housing and bolt pattern for the gearbox.
There are differences at least in feel. I had the transmission in my 03 Turbo replaced just recently due to a leaking selector shaft seal and the new transmission's shifting is much smoother/quicker than the original transmission's shifting. I had thought the original transmission's shifting feel "normal" and no tech commented on the shifting when I had the car in for service.
But the new/replacement (probably not even new but a remanufacturered) transmission quite an improvement over the old one.
Whether this improvement the result of some transmission revision made during the model run or just the difference between one orignal and not so good transmission, a transmission with performance at the low end of what is acceptable, and one replacement transmission that left the factory either with a nominal level or perhaps an above par level of shifting performance I can't say.
Oh, the Porsche techs told me the Turbo transmission and the NA 996 transmission share some components -- at least selector seals and such -- and had the car not been under warranty they could have disassembled the transmission and fixed it. It was replaced though cause the car still under CPO warranty.
Sincerely,
Macster.
Sincerely,
Macster.
Admin
Sincerely,
Macster.
Sincerely,
Macster.
Macster and all,
here is a summary of gearboxes:
G96.00 & G96.01 - 996 Carrera.
G96.30 & G96.31 - 996 C4
G86 is the Boxster version of G96/00
G96.50 - turbo
G96.88 - GT2
G96.90 - GT3
G96.96 - GT3 2004
the last 4 have the old type (G50) bell housing bolt pattern, the first three have different pattern and cant be swapped
All operate with cable-shifters.
Btw 996 turbo in its life cycle had only one gearbox the .96 but had 3 different versions of it one for normal, one for x50 kit and one for x75. Also had different versions of cables and shifters. (short shifters etc)
Hope this helps.
John
