Michelin cups
Not the case with the Nitto. The compound is such that is doesn't have the stick of a MPSC but lasts more than twice as long and is consistent from HC #1 to the end. It is actually faster at the end before cording as it becomes a slick.
the cups might have better stick but marginally better than nitto (or toyo's, i've tried RA1's and R888s) and considering the higher cost and shorter lifespan, forget it! if i want more stick, i'll go hoosiers
Hoosiers certainly are yummy, but I still need to learn how to drive. Seems a waste to run R6 for a couple days with great stick in the corners when my line is off, I'm not looking ahead consistently enough, not cornering to the limit of the tires....and when no prize money is on the line.
After my last set of Hoosiers, I've managed to put down the crack pipe and am running Nittos again. I'll come back to Hoosiers after I learn how to drive.
Cups have much more stick than Nittos and fractionally more than the Pirelli Corsas on my car at the moment. Too bad the Pirellis have been discontinued. I like 'em.
I don't like the Nittos at Tremblant at all.
Until you can get to that place where you are correcting the car BEFORE it gets unstable (instead of reactive) you have zero business running more grip.
Allan hit the nail on the head. What is your goal when on track? Do you want to have more grip or do you want to learn? Nittos are the perfect balance of stick and forgiveness. As you move up that grip ladder, your margin for error decreases exponentially. If you are running track pads, then that rules out street tires as they will outbrake them. Nittos/RA1/R888 allow you to have enough grip to run track pads but not too much that you fail to learn the limits of the cars.
