New brake rotor solution
Would be great if they can do 2-piece floating at $800.. and replacement disc at $500 or something like that.. then even if you have to replace the hat once every 2 seasons, the price will still be reasonable and you get the performance of the 2-piece floating setup.
I think the Giro is around $1,100-1,200 for a pair..
Cup ducts + track pads + good fluid + braking technique = flawless brakes in our cars.
Rotor type boils down to perceived performance differences wrt weight savings (I won't notice it, but an accomplished autoxer like Rad will probably want lightweight PCCB rotors vs boat-anchor Cayenne) and most importantly, cost/value for the rest of us mere mortals.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
"Drilled" rotors like oem will crack right away under hard use. Too much difference in temp by those holes and away from the holes including metallurgical imperfections around the hole sites to promote cracking. You will always have a problem with those rotors.
Slotted don't suffer from these problems as much.
I'm not interested in two-piece rotors due to cost and then it's another part (very important part) I need to worry about....when should the hats be replaced as the bobbins wear the holes over time? Why would I want to think about those little bolts and making sure they are tight enough? My driving is nowhere near being able to take advantage of any other differences between floating rotors and 1-piece so the extra expense/maintenance doesn't make sense for me.
Give me a solid slab of iron and I'll be happy. YMMV.
Rick DeMan: thanks for offering a great alternative to folks.
Cheers,
Cheers,
Basic Sponsor
My Pleasure..!!!
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
Porsche Sales & Service
Porsche Race services and parts
www.DeManMotorsport.com
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
Alan,
I don't disagree w/ you regarding the performance differential that you are talking about. i.e., the biggest limitation is still the driver and not some weight saving in the rotors.
But I guess my point was that if there's an alternative that is in theory better and is still affordable, why wouldn't we want that? If someone makes the 2-pieces rotors and you come out cheaper after factor into changing the hat every 2 or 3 rotors, why wouldn't that make sense?
Would I pay like $2k for a pair of Alcon or Brembo? Most likely not.. but if they are $800 a pair, and you can re-use the hat 2x or 3x, would I get them? Yeah, probably.. I guess that's what I am saying..
Fair enough. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Even at $800/pr plus $500/pr after that makes it $1300 for two pairs assuming replace the hats every second time.
ATE for Cayenne are $520 for the same two sets.
Rick's slotted solid iron version (lighter than ATE and properly made for our cars) is now (under?) $950 for two sets while on sale.
**** Assuming use the hats 3x: $1800 for 3 sets
ATE: $780
Rick's: $1425 on sale (potential price break available too. He's a good guy, just ask.)![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I don't know what the extra expense of 2-piece would be giving me in return? I see no benefit for my situation.....yet. I do have an open mind though.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Cheers,
ATE: $780
Cheers,
GT3 player par excellence
ATE: $780
Cheers,
ATE: $780
Cheers,
ur calc is highly flawed.
SOMEONE has to put the rotor on the hat for me.
there are quite a few bolts. WHO is doing that for me.
$120hour labor rate for most tech's.
i cannot do that myself.
you ask my mechanic how tight i can tighten things.
i stripped oil drain plug as well as the oil tank tread, i over torqued bleeder calipers, cross threaded the uprights putting caliper back on, overtightened the brk fliud reservoir cap and craked the cap and the reservoir neck.... some ppl are not meant to work on cars (like me) so i hire experts. and they cost money. so you need to add $100 for each time disc are replaced and put on the hat.
those who have more money should get the 2 piece, they are lighter and very good. but i dont have that extra $100 bucks. i go with heavy rotors.
Alan,
brembo and alcon are more than $2000 i assure you.
at least my brembo was more than that.
yes, two piece have benefits but at a cost.
i looked at pretty much ALL the alternatives before making my mind. then i dont trust myself so i buy most of the good alternatives and deplete my bank account (as you can see i am doing yet another experiment with 996gt3, soon i will own more 996gt3 than the porsche factory ever made hahaha). if you find a cheaper 2 piece deal, i am sure alan and i will jump on it.
oh. floating 2 piecs is even better (on paper at least) b/c it will always be parallel with pads. but they are very noisy.
sure, they now add spring loaded bobbins so no noise and still floating. but those bobbins cost more than non spring versions.
Cheers,
Cheers,
rick, we nor cal contingents just ordered 5 sets from ya today.
alan, so you are OCD like me worrying about bobbin and hats. i stare at my rotors and count from 1-10,000 in chinese, then in english then in spanish, then i drag out my daughter to ask her if she thinks the cracks are too big then i drag out my wife to triple chk then i drive the car to my mechanic to chk again. then i decide to fk it and put new rotor on.... i NEED HELP.
rad.... pccb. dont mention him. he's martian and my technical adviser. we should not use him as measurement
yeah, he told me to run 16" wide rear wheels
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
@mooty: Wow, popular belief is that two-piece is cheaper than single over the long term? Maybe if the two-piece is really needed for cooling and the singles wear out faster under a high heat application. Other than that, it's hard to believe. Yeah, you don't replace hats. But the extra cost for the fancy floating rotors negates that (at least the brands I've seen). I know I'm paying a lot more for my floating rotors than singles on my Audi. But I don't have a choice, it gets too hot...
Wait... Did the mods delete the post with the links posted by dan@jhmotorsports? I hope not because they just want to figure out if there is a market for a new product.
@cfjan: Yeah, there's so much talk about rotors, but only a few responses to this thread. I doubt this shop will make any development effort with the feedback here! What's the price of the Giros? If I recall, the pricing from the new solution would be under $1K. Which still seems a bit high, given they have something similar for closer to $600 with 320mm rotors.
popular believe is always wrong. just like democracy is wrong. see i am abnormal.
but you can try 2 piece and see if you like it. i stick to 1 piece after losing enough money on 2 piece
Mooty: great point about extra labor charges for folks who don't want to assemble something important like brake rotors at home. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I like 1-piece. Toss them on and you're done.
Cheers,
Cheers,
i string them up and use it to curl as free wt.
then use them as frisbee with my 18 month old.
he has many bruises.... his mom wonders why
^ yes, mooty for pres...
well that's if obama change the constitution to allow non native born martians to get elected.
i promise you that i will wipe out currency system such that we can just all barter with car parts.
