IO Port Racing cam mount position on cage
I received my IO Port camera mount and placed it as seen in the picture below. I thought that would be least visible behind the triangle-and-hole-thingy. Unfortunately part of the view is clipped by the seats. My setup is a GMG cage and euro GT3 seats.
Where is the best mounting position?
Thanks.
Thanks.
![](http://i983.photobucket.com/albums/ae311/crohani/IMG_8709.jpg)
@Number54, this is off-topic. Today I tried to install the I/O port mount on my DAS cage (1-3/4" I think) and found that the screw is not long enough (only 2-1/2").
Could you do me a favor and measure the length of those long screws? Greatly appreciated.
^u have to order with the longer bolts since das bar is thicker then most bars. They have the small length bolt set and the longer bolt set when u order online. I ordered the longer bolts. Mike
Thanks, I'll get some p-car brand. I'll post the bolt lengths later if mike hasn't already done it. They seemed pretty long for the GMG cage. And I have a pretty thick piece of rubber between the mount and the cage.
Well Webbie I looked at my bolt and now I remember the bolts were too short . My mechanic told me after he installed bar and tried bolting on ioport mount the bolts were too short so he ordered this c shape type clamp. You could probably call ioport if they have longer bolts or go to your nearest hardware store. Here's a pic of mine. Sorry I couldnt help u. Mike
Mine is obviously a little different than yours, but here is a picture anyway
I hope to mount a SmartyCam on it before my next event in late May.
Here is a link to the video for perspective. (vimeo link)
![](http://www.digitalsimple.com/GT3/04.16.10%20-%20Mount/forweb-DSC_1183.jpg)
