Transaxle fluid change
thanks dell... dumb question but, when i change the "transmission" fluid (aka "gear box"?), am i effectively changing the fluid in my "LSD" as well? i had the LSD replaced by the dealer last spring so did they have to drain the trans fluid as well so i should have fresh trans and LSD fluid in there due to the LSD change?
ivangene... where in WA state are you picking up delvac?
thanks again all
thanks again all
Not a dumb question at all. I didn't know when I first started learning about the cars as well ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Correct, you are changing the fluid for all. These cars have a transaxle which houses the tranny and diff in the same assembly.
![order](https://rennlist.com/forums/graemlins/order.gif)
![offtopic](https://rennlist.com/forums/graemlins/offtopic.gif)
Seth,
I see you are bring the LTW to Homestead maybe I can get Ian to follow you around the track for a couple of laps in my non LTW M3 just to compare performance.
Peter
