wheel bolts to run BBS e88 cups
just a quick one but i was wondering what wheel bolts those running BBS e88 on their GT3s used. ive got some cup spec wheels (center lock and 5 stud dual configuration) i am about to mount and was just wondering if i should be looking at longer bolts and if any are even available.
will i need to stud my hub?
the recess depth looks much longer than the current oem wheel.
thanks for the replies.
i figured i was going to be tight with the ones i had. ill get a set ordered up asap.
i am tempted to go the stud route....ive got the instructions for running them for daytona 24hr etc with the oem parts numbers.
this might be a winter project though, some long bolts will get me going right away![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
follow up......GMP lists 53 and 59mm options. is 53 enough? is 59 overkill?
