The clutch hydraulic fluid (brake fluid) may need bleeding at the slave cylinder mounted on top side of transaxle. The fluid comes from the brake fluid reservoir.
I change and bleed mine very two years.
This is a common thing on Vettes. Sometimes the clutch flush/bleed fixes it.
Give it a shot.
Good luck,
TomK
Just had the same problem this week. Mechanic said sometimes the rubber plunger inside the slave reverses itself. However on mine we found a small leak in the back where the line was rubbing on the sharp fins of the transmission cooler. Had to ship a new line from Gemrany and replace. Check carefully for leaks. If none try a bleed. If that does not work, maybe a new slave?
Nothings better then when it gets stuck- u use top of shoe to lift the clutch pedal back up. If it's a line possibly a warranty item don't know bout slave cylinder. Mike
