First set of Hoosiers -- need a bit of help
#46
I'm going to try 255/35 fronts next set. The diameter is 24.8 compared to 25.7 for the 245/40 which will lower the front end slightly and give a little more clearance in the fender well. I'm not expecting a significant change in handling; perhaps marginally better braking.
We had issues fitting the 255/35-18s on a 997 GT3.
#47
#48
Thanks for the input. The steering is certainly fine with the 245/40 and very similar to the Nittos I was running earlier. I'm not sure I'd like to mess with that....I'm running my first solo 1 event on the Hoosiers this weekend so I'll get a comparison to the Nittos. I'm hoping to drop from 93 seconds to 91 or 90. The ultimate goal being sub 90 secs but I'll need some suspension work to do that. I've been chatting with VA122 about revalving the shocks and stiffer springs.
#49
The following set up has worked well for me over the last couple of years. The tire wear has been perfect in either DE or Racing, and I have run
Wheels CCW with GT3 Wheel Offsets
Front 8.5X18 C10 ET40
Rear 11X18 C10 ET63
Hoosier R6
Front P245/40ZR18 -3.5 Camber
Rear P295/30ZR18 -2.6 Camber
Rear 11X18 C10 ET63
Hoosier R6
#50
Alex what are you running for tire pressures?
I ran the Hoosiers at our local solo 1 event on the weekend and reduced my best lap time from 93.6 to 92.4 seconds. I had a lot of trouble getting the pressures correct as it was a warm day and the tires gained 12psi. I found anything over 40 the tires became very greasy and that around 38 seemed to be the sweet spot. Overall the car was faster but felt very loose, predictable handling but seemed to have more oversteer than with the Nittos. The tires now have 12 HC's, lots of rubber but don't feel firmly attached to the pavement.
I'm running -2.3 R and -2.9 F, wear appears to be very even.
#51
Leigh have u thought of lowering pressures even more? I ran 31 hot all around on both Mpsc as well as kuhmos. I find nething over 36 it's not as grippy(it slides) Maybe try 34 hot. Mike
#54
I'll try lower and see how it works as the car certainly did slide. We're off to Miller next week for a 3 day PCA event so I'll be able to do back to back with the Hooters and the Nittos at different pressures.
#55
All I know is, they drop off fast with higher pressure, and over 12 heat cycles, it sucks but you have to pay to play unfortunately.. The 8 seconds I dropped from toyo r888's to r6's back to back in the same day, speaks volumes, I was doing things I never imagined in the car , carrying out so much damn speed it was unbelievable!
