Brake shims
lines already done- I prefer Motul 600, the extra Pads that came with car are R14- black Pagid. will install soon - when I use up stock rotors I will go to Deman's rotors. Temperature 23 degrees outside - so I not going anywhere yet.
Just heard back from Whitney at Speed bleeders- We will now have an application for 996 GT 3- I'll verify also for 997. Speed bleeders enable a 1 person brake bleed with the best final pedal of any system I've ever used over the years- Will post final info when confirmed
Personally I would go with a Motive power bleeder. It's a one person job as well and you retain the factory bleed valves. Do a search on the speed bleeders. IIRC, there was not got input from the guys here regarding them.
+1 motive PB! I also keep a squeeze bottle with me in case I need to bleed "old school"
I looked into those speed bleeders, quite pricey for just replacing bleed valves.
Now those tireleifs that bleed off air over whatever psi you set them at are really interesting
Here is how speed bleeders work- you put wrench on speed bleeder- attach hose to bottle- loosen bleeder 1/2 turn- get in car- press brake pedal down- release- etc- On 930 I got 9 pumps before I needed to refill reservoir. - tighten bleeder- pump for firmness- go to next bleeder- nothing better.
For stock pads and noise reduction you can use the spiders (aka shims or silencer pucks) and the spring tensioner on the top of the pads.
