996 GT2/GT3 Forum 1999-2005
Throttle induced understeer - solution?
Old 10-28-2008, 04:29 PM
  #46
LVDell
LVDell's Avatar
Originally Posted by 996FLT6
Dell- toe in for front gives more on center straightline stability(does not wander like toe out does). Streetwise it's safer since it understeers too. Easier to correct understeer then oversteer. All cars are set up that way. 171 mph- wasn't it fun dicing/slicing with Nasa? 1:49 ugh - I won't even be close to u. See u nov 7/8. Regards mike
Toe in REAR will give you that straight line stability and toe neutral in FRONT will be the best for accomplishing what you are always looking for....NEUTRALITY. The last thing you want is understeer in these cars. The front end is already light and the design is inherent to understeer. Exacerbating those inherent characteristics makes ZERO sense.
Set up the car as you wish but you will be chasing your tail all day long trying to get the "proper" setup if you start with toe in up front.
Old 10-28-2008, 05:33 PM
  #47
996FLT6
996FLT6's Avatar
My car is set with zero toe front 1/4 toe in rear which is the way I like at the track. Just saying all manufacturer's set up for understeer which is safer for the general public versus a neutral or oversteer set up. I understand what u are saying- my car is not set up for streets. Mike
Old 10-28-2008, 05:36 PM
  #48
mooty
GT3 player par excellence
mooty's Avatar
Received 5,660 Likes on 2,327 Posts
Originally Posted by mjb
Nice. Good clean lap considering the number of cars in that HPDE4 run group. 1:49ish!...smok'n fast as always Dave
149 what's the matter with you dave.
that's only 2 seconds ahead of me.
you need a 3.5 second gap
Old 10-28-2008, 06:01 PM
  #49
171mph
171mph's Avatar
the 1:49 looks good but actually 1:49.999999999 i think. also a lot of race rubber from the PRC guys so fast track on sunday i thought.
996flt6 - hi mike it was a lot of fun dicing with nasa. a well run group. see u there soon.
Old 10-28-2008, 07:28 PM
  #50
Carnerd
Carnerd's Avatar
Originally Posted by 171mph
Thanks Mike. I'm impressed with these nittos great feel
Holy smokes Potter! 1:49.9!?! That's freakin cookin man! I take it you were able to get the Motons dialed in properly. How do like the NT-01's compared to the Cups? Still think they are second slower?
Old 10-28-2008, 11:18 PM
  #51
D-Uber Cars
D-Uber Cars's Avatar
Camber,
Cans have 185 PSI.
Front Toe: 0 degree 04'
Rear Toe: 0 degree 15'
171mph,
Nice video, thanks for sharing.
Old 10-29-2008, 01:45 PM
  #52
171mph
171mph's Avatar
it's my first set of nittos so hard to tell but based on thill times i would say mpsc are prob good for .5 to 1 sec at outside but more likely around .5.
my nittos corded at rear after just 5 days (3 at THill 2 at SP) however i had too much rear camber so i think 6-7 days is possible. Fronts are still fine.
Quick Reply: Throttle induced understeer - solution?
