Any Experiences with Durametric Code Readers?
I'm thinking of getting this, particularly if my Air bag bypass proves not to work. If I have to keep resetting the airbag fault code for each annual state inspection, It will be cheaper than having the dealer keep doing it.
I have one too, and it works just fine. Just be aware that some of the codes it throws out are not accurate. For example, when I got a catalytic converter fault code, Durametric read it as a camshaft alignment above spec error.
I've had no problems clearing codes with it.
Thanks, everyone!
